SampleUserManagement.zip
8 KB
This article describes how to programmatically access the user and rights management that is part of the Automation Platform.
The following example shows how to perform the following tasks:
The user management is a system instance that implements one of the _3S.CoDeSys.UserManagement.IUserManagementXXX interfaces. To access it, use the following code:
IUserManagement userMgmt = (IUserManagement)ComponentManager.Singleton.InstanceFactory.GetSystemInstance(typeof(IUserManagement).FullName);
Starting from that point, you have got access to the user list, the group list, the password system ("authentication"), and the currently logged on users ("session").
Performing those tasks is quite easy with the interfaces that are provided. The commented code snippet should be self-explanatory.
try
if (UserMgmt is IUserManagement2)
((IUserManagement2)UserMgmt).BeginTransaction();
// Create a new group "Developers", if not existing.
groupList = UserMgmt.GetGroups(project.Handle);
developersGroup = groupList["Developers"];
if (developersGroup == null)
developersGroup = groupList.Create("Developers");
// Create a new user "John Doe" with password "JDoe" and make him a member of the
// "Developers" group.
IUserList userList = UserMgmt.GetUsers(project.Handle);
IUser johnDoeUser = userList["John Doe"];
if (johnDoeUser == null)
johnDoeUser = userList.Create("John Doe");
UserMgmt.GetAuthentication(project.Handle).SetPassword(johnDoeUser.Id, "JDoe");
if (!developersGroup.IsMember(johnDoeUser.Id))
developersGroup.AddMember(johnDoeUser.Id);
catch
SystemInstances.Engine.MessageService.Error(Resources.CannotAccessTheWorkspaceObject);
return;
finally
((IUserManagement2)UserMgmt).EndTransaction();
There are two groups in the user management system that are predefined and cannot be deleted:
If you need access to the Everyone group, use the following code pattern:
IGroup everyoneGroup = null;
foreach (IGroup group in groupList.GetAll())
if (group.IsEveryoneGroup)
everyoneGroup = group;
break;
Debug.Assert(everyoneGroup != null); // There is always one!
Likewise for the Owner group; just replace group.IsEveryoneGroup by group.IsOwnerGroup.
Every object in a CoDeSys project is controlled by the user management. There are four permissions on each object:
The information, which user group is allowed to execute each of those actions on a particular object are stored at the object itself, namely in a _3S.CoDeSys.Core.Objects.IObjectAccessProperty property associated with the meta object. So if you want to adjust those permission settings, you have to modify (or create) this property. Take a look at the following code snippet, which explicitly denies the modification right for the Everyone group, and which explicitly grants the modification right for the newly created Developers group.
IMetaObjectStub mos = SystemInstances.ObjectMgr.GetMetaObjectStub(project.Handle, objectGuid);
bool bNeedToModifyObject = false;
callback.TaskProgress(mos.Name);
// Read the object access property from the object. If it does not yet exist,
// create one.
IObjectAccessProperty accessProperty = mos.GetProperty(GUID_OBJECTACCESSPROPERTY) as IObjectAccessProperty;
if (accessProperty == null)
accessProperty = (IObjectAccessProperty)ComponentManager.Singleton.CreateInstance(GUID_OBJECTACCESSPROPERTY);
bNeedToModifyObject = true;
// Does a permission for the "Modify" access already exist? If not, create it.
Guid permissionId = accessProperty.GetPermissionId("Modify");
if (permissionId == Guid.Empty)
permissionId = Guid.NewGuid();
accessProperty.SetPermissionId("Modify", permissionId);
// Is the "Modify" access for the "Everyone" group already specified, and is it
// denied? If not, do so.
if (!accessProperty.IsPermissionSpecified(everyoneGroup.Id, permissionId) ||
accessProperty.IsPermissionGranted(everyoneGroup.Id, permissionId))
accessProperty.DenyPermission(everyoneGroup.Id, permissionId);
// Is the "Modify" access for the "Developers" group already specified, and is
// it granted? If not, do so.
if (!accessProperty.IsPermissionSpecified(developersGroup.Id, permissionId) ||
!accessProperty.IsPermissionGranted(developersGroup.Id, permissionId))
accessProperty.GrantPermission(developersGroup.Id, permissionId);
// If we modified anything above, make it persistent.
if (bNeedToModifyObject)
IMetaObject mo = null;
try
mo = SystemInstances.ObjectMgr.GetObjectToModify(project.Handle, objectGuid);
mo.AddProperty(accessProperty);
catch
SystemInstances.Engine.MessageService.Error(string.Format(Resources.CannotAccessObject, mos.Name));
finally
if (mo != null && mo.IsToModify)
SystemInstances.ObjectMgr.SetObject(mo, true, null);
When you open an arbitrary project and execute the Setup User Management... command, then the following things will happen:
During the execution of the command, you typically must login as an Owner (just use username Owner and empty password to continue). Read the next section what that is the case.
When making access right changes programmatically, the code is executing within the context of the currently logged on user. But what if that user has got restricted rights? Then your code will not work unless another user with sufficient rights exeuctes the code. This is typically not the desired behavior: the programmatic changes should work no matter which user is currently logged on. To achieve that goal, the user management system has implemented the concept of "user promotion". See the following code snippet:
ISession4 session = UserMgmt.GetSession(project.Handle) as ISession4;
if (session != null)
try
session.Promote("Owner");
// This code is executed within the context of the almighty Owner user, so every action is allowed.
// The user does not see this in the user interface.
finally
session.Demote();
However, in order to call the Promote method, your plug-in must have special code access security rights. That is the reason why we don't have that code in our download sample: our public samples do not contain a plug-in key and thus no special plug-in flags. If you need to get this code running, please contact us directly. If you run this code without CAS rights, CODESYS will terminate immediately.
8 KB
